Installing spice3 on RedHat problem
E-goe
Member level 5
Member level 5
Hi
After unzipping the "spice3f4_src.tar.gz" file and untarring the file I want to build Spice on my RedHat machine.
But there seemes to be a problem with that as he returns an error ( he says something about expecting 2 parameters and got only one ....?????)
Is there a problem in the "defaults" file. Do I need to make some changes in these file to install Spice properly???
PS default file attached, so maybe somebody can look at this file and give some comments, tips to install Spice.
Greetz E-goe
I am running on Athlon64 with FC3 x86_64. I am able to compile and run spice3f5sfix
you can see the details at ieng9.ucsd.edu/~ckpun
good luck
Hi
try also ng-spice (Next-Generation Spice) too.
1. h**p://ngspice.sourceforge.net/
* -> t
tnx
