Embeddedjoe
Newbie
Hi friends, thank you for the forum. I'm new to embedded and loving it (please pardon my ignorance and help me to learn).
I'm trying to blink an msp430fr5969 using win 10 OS, msp430-gcc cross compiler, and mspdebug to program the chip; but I'm having trouble installing mspdebug - I cant find a forum specific to mspdebug; I thought you fellas might have some experience.
Following the instructions on mspdebug,
after downloading and extracting, with my terminal in the mspdebug-0.25 dir, when I run 'make' I get:
The next step would be 'make install', but I see no binary in the directory:
I looked around in the makefile, but I dont understand it enough to trust myself to make changes:
Thank you
CC ?= gcc
INSTALL = /usr/bin/install
PREFIX ?= /usr/local
LDFLAGS ?= -s
BINDIR = ${PREFIX}/bin/
MANDIR = ${PREFIX}/share/man/man1
LIBDIR = ${PREFIX}/lib/
UNAME_S := $(shell sh -c 'uname -s')
UNAME_O := $(shell sh -c 'uname -o 2> /dev/null')
ifdef WITHOUT_READLINE
READLINE_CFLAGS =
READLINE_LIBS =
CONSOLE_INPUT_OBJ = ui/input_console.o
else
READLINE_CFLAGS = -DUSE_READLINE
READLINE_LIBS = -lreadline
CONSOLE_INPUT_OBJ = ui/input_readline.o
endif
BSLHID_OBJ ?= transport/bslhid.o
RF25000_OBJ ?= transport/rf2500.o
ifeq ($(OS),Windows_NT)
MSPDEBUG_CC = $(CC)
BINARY = mspdebug.exe
ifneq ($(UNAME_O),Cygwin)
OS_LIBS = -lws2_32 -lregex
OS_CFLAGS = -D__Windows__ -DNO_SHELLCMD
RM = del
endif
else
MSPDEBUG_CC = $(CC)
BINARY = mspdebug
ifneq ($(filter $(UNAME_S),OpenBSD NetBSD),)
OS_LIBS =
else ifneq ($(filter $(UNAME_S),FreeBSD DragonFly),)
OS_CFLAGS = -pthread
OS_LIBS = -lpthread
else ifneq ($(filter $(UNAME_S),SunOS),)
OS_LIBS = -lpthread -ldl -lresolv -lsocket -lnsl
else
endif
ifeq ($(UNAME_S),Darwin) # Mac OS X/MacPorts stuff
ifeq ($(shell fink -V > /dev/null 2>&1 && echo ok),ok)
PORTS_CFLAGS := $(shell pkg-config --cflags hidapi libusb)
PORTS_LDFLAGS := $(shell pkg-config --libs hidapi libusb) -ltermcap -pthread
else ifeq ($(shell brew --version > /dev/null 2>&1 && echo ok),ok)
PORTS_CFLAGS := $(shell pkg-config --cflags hidapi)
PORTS_LDFLAGS := $(shell pkg-config --libs hidapi) -framework IOKit -framework CoreFoundation
else
PORTS_CFLAGS := -I/opt/local/include
PORTS_LDFLAGS := -L/opt/local/lib -lhidapi -framework IOKit -framework CoreFoundation
endif
BSLHID_OBJ = transport/bslosx.o
RF25000_OBJ = transport/rf2500hidapi.o
LDFLAGS =
else ifneq ($(filter $(UNAME_S),OpenBSD NetBSD DragonFly),)
PORTS_CFLAGS := $(shell pkg-config --cflags libusb)
PORTS_LDFLAGS := $(shell pkg-config --libs libusb) -ltermcap -pthread
else
PORTS_CFLAGS :=
PORTS_LDFLAGS :=
endif
endif
INCLUDES = -I. -Isimio -Iformats -Itransport -Idrivers -Iutil -Iui
GCC_CFLAGS = -O1 -Wall -Wno-char-subscripts -ggdb
CONFIG_CFLAGS = -DLIB_DIR=\"$(LIBDIR)\"
MSPDEBUG_LDFLAGS = $(LDFLAGS) $(PORTS_LDFLAGS)
MSPDEBUG_LIBS = -L. -lusb $(READLINE_LIBS) $(OS_LIBS)
MSPDEBUG_CFLAGS = $(CFLAGS) $(READLINE_CFLAGS) $(PORTS_CFLAGS)\
$(GCC_CFLAGS) $(INCLUDES) $(CONFIG_CFLAGS) $(OS_CFLAGS)
all: $(BINARY)
clean:
ifeq ($(UNAME_O),Cygwin)
$(RM) */*.o
$(RM) $(BINARY)
else
$(RM) drivers\*.o
$(RM) formats\*.o
$(RM) simio\*.o
$(RM) transport\*.o
$(RM) ui\*.o
$(RM) util\*.o
$(RM) $(BINARY)
endif
else
clean:
$(RM) */*.o
$(RM) $(BINARY)
endif
install: $(BINARY) mspdebug.man
mkdir -p $(DESTDIR)$(BINDIR)
$(INSTALL) -m 0755 $(BINARY) $(DESTDIR)$(BINDIR)
mkdir -p $(DESTDIR)$(MANDIR)
$(INSTALL) -m 0644 mspdebug.man $(DESTDIR)$(MANDIR)/mspdebug.1
mkdir -p $(DESTDIR)$(LIBDIR)/mspdebug
$(INSTALL) -m 0644 ti_3410.fw.ihex \
$(DESTDIR)$(LIBDIR)/mspdebug/ti_3410.fw.ihex
.SUFFIXES: .c .o
OBJ=\
util/btree.o \
util/expr.o \
util/list.o \
util/sockets.o \
util/sport.o \
util/usbutil.o \
util/util.o \
util/vector.o \
util/output.o \
util/output_util.o \
util/opdb.o \
util/prog.o \
util/stab.o \
util/dis.o \
util/gdb_proto.o \
util/dynload.o \
util/demangle.o \
util/powerbuf.o \
util/ctrlc.o \
util/chipinfo.o \
util/gpio.o \
transport/cp210x.o \
transport/cdc_acm.o \
transport/ftdi.o \
transport/ti3410.o \
transport/comport.o \
$(BSLHID_OBJ) \
$(RF25000_OBJ) \
drivers/device.o \
drivers/bsl.o \
drivers/fet.o \
drivers/fet_core.o \
drivers/fet_proto.o \
drivers/fet_error.o \
drivers/fet_db.o \
drivers/flash_bsl.o \
drivers/gdbc.o \
drivers/sim.o \
drivers/tilib.o \
drivers/goodfet.o \
drivers/obl.o \
drivers/devicelist.o \
drivers/fet_olimex_db.o \
drivers/jtdev.o \
drivers/jtdev_bus_pirate.o \
drivers/jtdev_gpio.o \
drivers/jtaglib.o \
drivers/pif.o \
drivers/loadbsl.o \
drivers/loadbsl_fw.o \
drivers/hal_proto.o \
drivers/v3hil.o \
drivers/fet3.o \
drivers/bsllib.o \
drivers/rom_bsl.o \
drivers/tilib_api.o \
formats/binfile.o \
formats/coff.o \
formats/elf32.o \
formats/ihex.o \
formats/symmap.o \
formats/srec.o \
formats/titext.o \
simio/simio.o \
simio/simio_tracer.o \
simio/simio_timer.o \
simio/simio_wdt.o \
simio/simio_hwmult.o \
simio/simio_gpio.o \
simio/simio_console.o \
ui/gdb.o \
ui/rtools.o \
ui/sym.o \
ui/devcmd.o \
ui/flatfile.o \
ui/reader.o \
ui/cmddb.o \
ui/stdcmd.o \
ui/aliasdb.o \
ui/power.o \
ui/input.o \
ui/input_async.o \
$(CONSOLE_INPUT_OBJ) \
ui/main.o
$(BINARY): $(OBJ)
$(MSPDEBUG_CC) $(MSPDEBUG_LDFLAGS) -o $@ $^ $(MSPDEBUG_LIBS)
util/chipinfo.o: chipinfo.db
.c.o:
$(MSPDEBUG_CC) $(MSPDEBUG_CFLAGS) -o $@ -c $*.c
Thank you
[MODERATOR ACTION]
- Enclosed above code within CODE tags
