Installation problems
eruisi
Member level 4
Member level 4
CA
I installed Astro2004, IC5114 and LDV50 on Redhat ES3.
After launching IC or LDV, I kept getting a bunch of the following error messages:
"Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed."
But the softwares can be launched.
"setenv LD_ASSUME_KERNEL 2.4.1" can overcome this but Astro2004 would fail.
Is these errors critical or not? How to fix them?
Thanks in advance!
This error appears frequently and shouldn't harm u
Then you can set this environment variable for IC and LDV only. This can be done by script file, shell function or aliases. For example:
alias icfb="LD_ASSUME_KERNEL=2.4.1 command icfb"
or
function icfb()
    LD_ASSUME_KERNEL=2.4.1 command icfb "$@"
    eruisi
Redhat ES3 have kernel 2.4.x and do not need set LD_ASSUME_KERNEL !
I dont think that you need to worry about this problem
