Installation of FTDI D2XX drivers on Windows XP SP1
Mercury
Member level 3
Member level 3
Hello,
I'm trying to install the FTDI D2XX drivers in my Windows XP SP1. I've used the program to change the PID and that worked. The problem is that when I run the "Found new hardware wizzard" and point to the driver location I get an error (message) "The specified location does not contain information about your hardware". So what sould I do to install the drivers?
George
Re: FTDI D2XX drivers
Specify the correct driver path along with the drive letter where the driver exist. Sometimes you have to remove the old drivers and then press refresh for automatic search and install.
I tried manually typeing the path and filename, but it's no use. About the drivers - which ones and how do I uninstall them, and where is the refresh button?
Best regards
George
