Install Hspice in centOS 6.4
Basma Gamal
Newbie level 3
Newbie level 3
I am trying to install Hspice on centOS
FIRST, the synposy installer should be started by running installer -gui , I tried to follow that step by typing
installer -gui & ./installer -gui
BOTH GIVES ME THE SAME OUTPUT
/usr/local/hspice/install/install_bin/Linux/bin/tclsh: /usr/local/hspice/install/install_bin/Linux/bin/tclsh: cannot execute binary file
I am not good at linux so I don't know where I should start to solve that or what is wrong
I appreciate any help , Thank you in advance
The most probably You try to run 32 bits binaries on pure 64 bits system or vice versa.
If You have 64 bits system You would have to install 32bit version of libc6 and libelf libraries.
By using Midnight Commander internal viewer You are able to check version of tclsh binaries (command mcview /usr/local/hspice/install/install_bin/Linux/bin/tclsh)
