Inserting parameters of a transistor
navidh91
Newbie
Newbie level 3
hello
i want to import these parameters
to this s2p to check stability of transistor
i dont know how to insert these parameters
Why don't you calculate by hand ??
I want to design an amplifier with the above specifications and the following assumptions using ADS software. I finally managed to enter the S parameters into the software. Now I want to enter the values of the load reflection coefficient and transducer gain into the software but I don't know how to do this
Assuming that the load reflection coefficient is 0.66∠105, for amplifiers with transducer gain of 6 dB and the minimum possible noise figure in this case, what are the source reflection coefficient and noise figure of the designed amplifier?
And i attached my s2p file too.
Thanks a lot for your help
  • s2p.txt
LaTeX Commands Quick-Menu:
