gerbold
I've built a hot-wire device for cutting polystyrene. I used a computer power module (ATX-350) drawing off from the 12v rail/line. I've use 28 gauge Nichrome wire. The arrangement works insofar as the wire heats up to orange glow. However I feel I need a fine control. I bought a Lutron dimmer switch but have since discovered this is appropriate to the AC side and would not have any affect on DC regulated voltage. I did actually insert it but, given the disparity in function, teh obvious happened; nothing. It appears that, on the DC side, I need to control amperage rather than voltage. Can any member suggest a device which I could insert into the circuit? A LED dimmer switch has been suggested (12volt DC 8amp) but the potential amperage on the ATX may be as high as 17amp max. I sense using any device rated less could lead to an overload situation. Perhaps too a switch, fuse and indicator would be sensible insertions into such a circuit. Suggestions please. Thanks in anticipation of your assistance.
