Do you have frequency offset option in your VNA ?Now I am using VNA to measure the input impedance of multiplier diode(PIN diode).
1 is correct, if output of BPF is terminated correctly.It shows different input impedance for two cases:
1: when I connected VNA at input port of diode and connect the BPF at the other port of diode.
2: when I connected VNA at input port of diode and terminate the other port with 50 ohm termination.
Which one is correct configuration?
How do you feed local signal to diode ?
Right.VNA has a power range from 0dbm to 10dbm.
I set the power level of 9dbm.
This multplier diode dont need seperate dc biasing.
The purpose of all this exercise is to match the input port of multiplier diode.
Am I doing right so far??
What do you refer ?I am not getting your last comment.
What do you refer ?
The HSMP-3822 is a PIN diode. The "I" in PIN means there is an energy storage "intrinsic layer" that will make this diode work a little like a "Step Recovery Diode". In other words...it multiplies because it is a highly nonlinear device. That is Idiode= (a very nonlinear function of the input voltage).
So simply hooking the diode to a VNA is NOT going to simulate the correct LARGE SIGNAL conditions of the diode when it is properly running. i.e. when there is an input matching/lowpass filtering mechanism, when there is some sort of 2nd harmonic tuning (idler frequency tuning), and when there is a highpass/matching network on the output. So a VNA will tell you not too much, even IF you could get enough power out of the VNA.
SO, you have two methods to get at the impedance of the diode when it is operating properly terminated:
1.) Calculate the effective impedance from some past papers. There is a book by Penfield and Rafuse that explains the equivalent impedances at Fin, 2Fin, and Fout.
http://techdigest.jhuapl.edu/views/pdfs/V04_N2_1964/V4_N2_1964_Thompson.pdf
There is also a classic HP application note 920 on step recovery diode multipliers.
I can give you half of the answer, the effective capacitance is approximately Ceffective = 2 X (the capacitance at Vbreakdown). For the real part of the input impedance of the diode, refer to the above papers
or
2) use a non-linear analysis program to calculate it all for you with a non linear simulation. However, usually these programs have a very poor model for a step recovery diode (do not include the charge storage mechanism) and therefore can give questionable results.
this program might yield a good start point for a nonlinear analysis:
http://www.flambda.com/srd.html
Even if the PIN or SRD diode multipiers operate as parametric devices, we can measure large signal s11 by VNA as far as configuration as frequency multiplier is complete.
Here "complete" means all circuits necessary for proper mode operation are euipped at both input and output.
See start of this thread.Parametric SRD multipliers usually run at +17 dBm or more
This tripler can work for input=10dBm@100MHz and output=300MHz.
I don't think this tripler work as parametric circuit.
Simply it works based on I-V nonlinearity.
