Hi
Do you agree, that in the attached (LTspice and PNG) boost converter,
the input impedance of the error amplifier is 47k + 17500R_in_parallel_with_2500R?
this should be correct. You can also check this in your simulation by plotting the voltage at the cathode of D1 divided by the current towards the FB pin e.g. I(R4). Here you will see most likely some impact of the compensation network at higher frequencies. I haven't run your simulation.
