rragupathiraja
Newbie level 5
I want to design an inverter for household applications. (230V @50HZ frequency is requirement). the DC supply voltage is 48 Volts. it requires a DC-DC converter to step up the voltage.
I can go with boost converter to boost the voltage. But i was not able to find, to which voltage it should be boosted to convert it into the equivalent 230V AC magnitude?
thanks..
thanks..
