Inport/Outport in Windows NT Server
0levanhoc
Junior Member level 2
inportb和outportb改成_inpb和_outpb
How to Inp/Out Port in Windows NT Server?
You must write the WDM driver.The best tool is vtoolsd
inport outport on win2k
Hello
Look in beyondlogic.org and allowio it seem to be simple and usefull
So, antoher time, there is DlPortio and or UserPort that do the job for you !
for example :
(DlPortIo offer function that can be use to acess IoPort, UserPort permit ALL program to simply use inp(), inportb(), outportb(), and so on, to all process)
I posted BeyondLogic prog in the topic about XP access (same Programming forum)
It should work under NT server.
Try Windows NT DDK !
Windows 95/NT Port I/O Driver
The easiest way is to use GIVEIO driver.
It allows to use standard C functions
inpb inpw inpd outpb oupw outpd.
Try to find GIVEIO with any search eng.
