Initialize two comm port in visual C++
ryusgnal
Full Member level 1
Malaysia
setcommport
I use this command to initialize my Comm Port in port 1
m_Comm.SetCommPort(1);
m_Comm.SetSettings("9600, n, 8, 1");
m_Comm.SetPortOpen(TRUE);
How to initialize one more comm port which is in port 2?
How to control both comport? Example: I want to receive data from comm1 and send whatever i receive to comm2.
Thank you...........
setcommport(
its quite simple. You just instantiate another object from Communication object. I don´t know wich object, but, let´s suppose you did this:
COMMSerial Comm;
alright? now, just do this:
COMMSerial Comm_2;
m_Comm_2.SetCommPort(2);
m_Comm_2.SetSettings("9600, n, 8, 1");
m_Comm_2.SetPortOpen(TRUE); .
best regards, and happy holidays
Breno
::eek:noncommmscomm1
just add another control, if only your PC has two serial ports.
posting comm port event
Yes my PC have two comm port.
am I need to add another "Microsoft Communication Control" (as shown in the picture) or not?
Showing in the picture is what I already did and I already add another comm port initialization as suggested above. when I compile the program, everything is o.k. But when I try to execute the program, nothing happen (the program doesn't executed). Anybody know what is wrong?
Thank you....
how to do port initialization in c
yes, you will need two control if you use mscomm control.
visual c++ profiler com ports
But why when I run the program, Nothings happen?
m_comm.setcommport(1);
did you initialized the code seperately? and check which port # when there is a COMM event?
commport in c++
for Serial port initialize I do this:
// TODO: Add extra initialization here
m_mscomm.SetCommPort (4);
m_mscomm.SetSettings ("9600,n,8,1");
m_mscomm.SetPortOpen (TRUE);
m_mscomm2.SetCommPort (5);
m_mscomm2.SetSettings ("9600,n,8,1");
m_mscomm2.SetPortOpen (TRUE);
return TRUE; // return TRUE unless you set the focus to a control
If there is Comm Event in Port4, I do this:
void CBasicmodemDlg::OnOnCommMscomm1()
UpdateData();
CString data;
CString str;
COleVariant myVar;
myVar = m_mscomm.GetInput ();
data = myVar.bstrVal ;
m_rx = m_rx + data;
UpdateData(FALSE);
And if there Comm Event in port5, I do this:
void CBasicmodemDlg::OnOnCommMscomm2()
// TODO: Add your control notification handler code here
if (m_mscomm2.GetCommEvent()==2)
VARIANT in_dat;
in_dat = m_mscomm2.GetInput();
CString strInput(in_dat.bstrVal);
m_tx = m_tx + strInput;
UpdateData(FALSE);
