InfraRED Tx Rx module
ricky_wcy
Junior Member level 3
infrared tx rx
HI folks,
I need to use InfraRED Tx RX module is new project.
I do not have such experience.
Any any guys give some recommendation to me
1. module no. or part number ?
2. normally standby current of both Tx & Rx module ?
3. Any class ? (i.e range limit for each class) Just like bluetooth there is class 1 (100m) & class 2 (10m)
Thanks,
ricky
she00044ced.pdf
chk out this link.might help for understanding the concept.
ir tx rx pdf
Some IR emmiters:
tsal6100 data sheet:
http://www.rentron.com/Files/tsal6100.pdf
More here:
http://www.rentron.com/remote_control/IRLED.htm
Narrow or wide half angle will depend on your application.
Detectors:pNA4602M cheapest For me anyway
http://www.semicon.panasonic.co.jp/ds/eng/SHE00044CED.pdf
Vijay TSOP serie:
http://www.rentron.com/Files/TSOP11xx.pdf
Match the wavelength of your emmiter to your detector.
This should get you pointed in the right direction.
Good luck.
infrared tx & rx module
How to calculate the current consumption I turn IrLED (Tx, Rx)
Conditions:
1. Turn on for 24 hrs (both Tx, Rx)
2. Max. driving current = 60mA
infrared tx & rx
Conditions:
Check the links I provided,all your questions will be answered ,read some of the datasheets.You can calculate total power consumption by EI were I is the average current in (for Tx this will be a pulsed square wave on a DC component). Or do what I do build the cct and measure with an scope to determine power in.
Direct link for Duty-Cycle vs. Output Power
http://www.rentron.com/PicBasic/infrared_object_detection.htm
