Infrared heater control board
tkt0011
Newbie level 2
Newbie level 2
First of all, I am apologize if I post in the wrong section. Please remove/move if the case.
I have 3 infrared heaters that exhibit the exact same problem. The front panel control and lights are not working. All the buttons on this panel do nothing when pressed. All the lights are off. However I can use the remote control (RF) to turn on the heater even though I can't see anything on the front panel. When pressing the power button on the remote I can hear a beep and I can use the temperature button (+/-) also on the remote to turn on/off the heater.
Brand: Heat Wave (or Athens) from Home Depot.
Model: WW13011
URL manual: https://images.homedepot-static.com/catalog/pdfImages/85/85a42a39-3dec-40af-9c83-70c291173dc5.pdf
Here's the picture to the front of the panel circuit board:
Back of the circuit board:
The red marks are when I measure voltage between those two points. Same for all the LED legs.
Can anyone help me diagnose this board? I have a very limit understanding of electronic circuit.
Thank you very much.
I'm not familiar with the model, there are no Home Depot outlets in my country but from your photographs it would seem there is another board in the heater that actually does the 'thinking' and the one you show is only to handle the display and switches. That narrows it down to two possibilities, either the board you show is faulty or it isn't communicating with the other board.
Can you try to read the number marked on the black IC on the copper side of the board please, or better still show a close up photograph so we can see if it has a manufacturers logo on it. The signal from the remote control receiver goes straight to the connector so it doesn't pass through that IC but everything else does.
Brian.
Thanks Brian for responding.
I look at the IC with magnifier and there is no information written on it. No mark at all or maybe it was removed. Thanks for the tip about how the signal from the remote goes straight to the other board. There is another board behind the heater inside I haven't looked at yet. I will remove that board to investigate. Since there is power to some section of the front circuit I thought the problem probably just here. I will check the other board and get back. Thanks again.
Model: WW13011
i have same issue which was fixed by replacing the power push button on the control panel after a period push button start malfunction
Fragrance
