information needed on the effect of backbias on mismatch
rubink
Member level 1
Member level 1
mismatch with backbias?
Anyone got any information on the effect of backbias on mismatch? I have a circuit which is varying more than expected. The foundry model doesn't take the effect of backbias on the mismatch, which could be part of the problem. I found a few papers which showed mismatch was worse with backbias, particularly in weak inversion but only limited data so far.
Any data or links gratefully received.
Thanks,
R
Re: mismatch with backbias?
Example paper
Some data from a different for 1.8V nmos from a different 0.18u process.
This confirms that increasing backbias increases backbias.
I guess nobody would ever question this! :D SCNR!
But jokes aside: you got your confirmation. Thanks for sharing the picture!
