Info about eye diagram measurement
ninor
Newbie level 1
Newbie level 1
Does somebody have ideas where I can get the information about eye pattern?
Thanks!
eye pattern matlab
This is a very general question! What type of information are you looking for?
An eye pattern is generally used to look at some parameters of a signal like jitter, rise and fall times, overshoot and undershoot levels, ...
Regards, TurboPC
eye diagram usb
www.dolphin.fr have some spice like tool called "Smash"
and it also support Eye pattern, but I think maybe it have bug
I use smash examples eye_pattern , but when I use
eye pattern offset=1u period=1u , it will show
"no enough memory available tocontinue"
but I have 256M Dram on PC ..
why ? smash have bug ??
usb eye pattern design
smash will fix eye pattern select problem ..
eye pattern tektronix
You can take a look of transmitter spec. of any PHY device, such as ethernet, USB, etc.
ethernet eye pattern
HP or AGILENT has several tutorials on his web site about measurement.
Among these you will find informations about eye diagrams.
eye pattern
a new spice tool called "SpiceExplorer"
It can generator eye pattern for FFT histgram analysis
I think it is good for help spice analog designer
eye pattern overshoot
You may want to try matlab. In simulink you can easily see the eye pattern.
regards
phy vs eye pattern in a tektronix scope
but how to use matlab to see the eye pattern?
anyone have the detail ?
matlab program for eye pattern
Visit Tektronix web site
Please give direct link.
Cluricaun
usb & eye pattern
Here is a link from tektronix website for communications eye diagram measurements
USB eye diagram measurements
Search tektronix website they have lot of tutorials on eye diagram measurements
usb eye digram
Looking for @glient Web, Application PDF article in
@oogle Search web
