Infinite ground plane + antenna
Biker12
Newbie level 1
Newbie level 1
Hi all, Im new at the FEKO`s world and Im building a fractal antenna, to do that I used a cilinder as the port conector and I set the lateral surface as a port. Also I set a infinite ground plane. When I run FEKO I received the following message:
WARNING 498: Observation point is not allowed to be in/below ground plane
See also message in the output file TEMPo_Out
I dont know if Im doing the right thing, I need some one who can help me with that.
Thanks.
