SK245230
Member level 3
Hi dear friends,
I have some questions about ferri/ferromagnetic materials for boosting Inductors Q factor. This sort of things is out of my knowledge so I don't know how to properly choose the right magnetic material for an application. As far as I understand things, for any magnetic material permeability varies with frequency, and the higher is the permeability, the higher I will increase my Inductance value L and Q factor. It looks like there is a kind of trade off between high permeability and high frequency for any magnetic material (similarly to the trade off between the bandwidth and amplification for an amplifier).
First question, what data do I need to look for in a datasheet?
Second question, suppose the permeability of the ferrite is constant, if I combine the inductor and the ferrite, will it move the resonant frequency of the inductor?
Third question, the resonance of the ferrite sheet should be before/after/same as the resonant frequency of the inductor? What will happen if it's different?
Fourth question, how to choose the thickness of the ferrite material?
My final objective would be to use a magnetic material (ferrite sheet or other if thickness is needed) in order to isolate and boost the quality factor of a 5cm inductor working in the range of 1 to 10MHz for Wireless power transfert
If some have interesting lecture concerning this, do not hesitate to give the reference.
Thank you
Thank you
