usama14
Member level 5
Hello everyone.
I am designing an H-Bridge based SPWM inverter converting 330VDC(48V converted to 330VDC by Full Bridge converter) to 220VAC. The problem has come down to the filtering issues. When I used only 48VDC to convert it into an AC, I achieved a pure sinewave with ta toroidal core(dont know the material). But when I perform the same testing with the 330VDC, I am not getting the sinewave. I think the core is saturating because I connected a resistor in series with the inductor(a second order LC filter), and I was achieving a pure sinewave but with a lot of power being dissipated across the resistor.
Please give any suggestions related to this problem. Also, if the core IS saturating, kindly tell me which core should I use for filtering?
Thankyou a lot. (This is my Final Year Project and is in the last stages. So, kindly help asap)
