csdave
Member level 5
Hi all,
I am trying to understand inductors better and I have a question that I can't get an answer for.
Assume I have a circuit with a generator, an ideal switch, an inductor and a resistor all in series (nothing in parallel with the inductor).
I turn on the switch and the current increases exponentially as the voltage across the inductor decreases from the generator's voltage to 0.
I leave the circuit on for a while,
then I open the switch. Current would want to stop, but it continues for a while because of the inductor, right? This generates an EMF (opposite to the one we had when closing the switch) across the inductor.
Now, what happens to this EMF if the switch remains open (and it's ideal, infinite R)? Does this EMF grow indefinitely? Does it generate a current across the inductor?
I thought of this, because I was thinking of capacitors and of the fact that if you remove a charged capacitor from a circuit, it will remain charged (ideally forever, in practice until the charge escape through parasitic resistances). Is there an equivalent phenomenon for an inductor? Or is an inductor without a generator simply a piece of wire?
Thanks to anyone who can answer.
