spudboy488
Full Member level 5
I'm designing a daughter board using OrCad Layout (old, I know). The board has 2 40 pin connectors at opposite ends. Both connectors have VCC net connections to the main board. The main board has the power supply and supplies VCC to multiple pins on each connector. I routed the board to use the closest VCC pin on a connector.
The issue I am having is that when I check connectivity, it shows all the VCC pins on each connector not being connected to each other as they are actually connected together on the main board. Short term, I added routes to all the VCC pins between the 2 connectors so I can check to see if I'm missing any other connections. I would rather not leave the connections there.
The question: Is there a way to indicate that multiple pins are connected externally from the PCB so Layout doesn't show them as being disconnected?
