Indexing using #define
akshaybhavsar
Full Member level 2
Full Member level 2
Hello,
I have to extract packet information which is stored i array.I have to extract each byte.
I have to set index for each byte like
#define byte1 1
#define byte2 2
I have almost 70 bytes in packet.I cant do it 70 times.
I have to do somethning if possible'
#define byte_x (_x)
Please tell me any other way.
If you want to read the array from beginning to end in sequence then why do you use a variable like
unsigned int i = 0;
to use as array index ?
const char value[] = { 1, 2, 3, 4, 5... n }; -> array of char stored in flash
const char * names[] = { "James", "Peter", "Kumar ukurich" ... };
Unless each byte represents a distinc parameter, there is no other tricky way to do that; otherwise, if the whole array is only one datum, you just need to know the lenght of the array. Its address you can get straight with C statements, as for example the '&', and you can handle the index by incrementing an offset added to it.
