maheshkuruganti
Earthing Question
I have to make a Independent 30V 10A Power Supply. It has to be such that we should be able to Series and Parallel for more Voltage or Current. Now That is simple enough. But I now Earth the chassis and also the Secondary of the Transformer.This would then rule out any combination so my question is should the Secondary of a Transformer be Connected to Earth or not.Please tell me whether I should ground only the chassis or both.Thank You
P.S:I use a metal case.:
