powersys
Advanced Member level 1
eccentricity error encoder
An incremental encoder is attached to the motor shaft, and the output signals from the encoder is used to calculate the speed of the motor. If there is some misalignment between the shaft and the encoder, do you think the calculated speed will be constant or consistent? Assume that the motor speed is constant.
Besides, if the encoder is wobbling, do you think the calculated speed will be constant?
