Increment in Labview on mod 10
engr_joni_ee
Advanced Member level 3
I am new in Labview and want to make a program which increment when the loop index mod 10 is 0, i.e. when loop index is 0, 10, 20, 30 ....
I attach a program which has a Boolean indicator whenever the loop index mod 10 is 0. The Boolean is connected to case statement but how to define a variable and increment it when the case statement is true ? I would like to have a counter inside the case which shows the number of times the case statement is true.
You can use a LabVIEW "shift register".
You can initialise a variable to zero from outside all your loops and wire through to your inner loop, where it is incremented. Where your wire passes through the outer loop (on the left), right click and change to shift register. This will change its icon and also create another matching one on the right edge, into which you should wire the incremented value.
I hate LabVIEW for so many reasons. I advise you to avoid it at all costs.
