The_Dutchman
Member level 1
Hello all,
For my specific problem I need to increase some PMOS NWELL sizes from the PDK transistors. In my simulations I always used 5 terminal PMOS (S G D B PSUB) devices.
However in the layout, there is already a guard ring around the nwell, leaving no option to draw a bigger NWELL.
I tried to use a 4 terminal PMOS (without PSUB) in layout , then draw a bigger NWELL and do LVS. However there is a transistor mismatch (4 terminal vs 5 terminal). I can fix this by also putting the 4 terminal PMOS in my schematic, but then I don't have any PSUB connection anymore?
I don't see how I should fix this hierarchy issue? Should I use the 5 terminal model, flatten, and edit? Cause I don't like flatting the models from the PDK. Furthermore, how can I ensure to still get good PEX results?
Please help!
Please help!
