msyrjala
current drain
I have a following kind of setup:
1. Battery (LiFePO4, 3.2V) driving a switcher (ADP2504), components according to datasheet (10uF input, 2*10uF output, 1uH coil)
2. Load is Freescale MCF51QE128, Atmel flash. Totaling about 20uF caps, two LC-filters to smooth Vcc for ADC section.
Here's what happens:
When I power up the load from DC source, the idle current is 30uA. Very good.
When the load is powered from the ADP2504, the voltage has 100mV ripple due to PSM (power saving mode). The DC current drain is now 400uA (with ripple according to voltage).
I tried powering the load with function generator using a similar waveform (DC+ripple), but the current is now again 30uA+associated ripple.
Any guesses where to continue hunting ?
