Increase PWM frequency with 68HC11 ??
Mr.Cool
Advanced Member level 2
pulse width modulation hc11
I am using a 68HC11 microprocessor to control the switching element in a Boost Converter application. however, the maximum frequency capable of the 68HC11 is not even close to being what i desire.
68HC11 max frequency is based on the crystal frequency, mine is 4MHz. so using 8 bit PWM resolution, i can obtain somewhere around 15KHz max frequency. i require upwards of 60KHz.
i do not want to switch microcontrollers. i can not run the 68HC11 faster (i.e. i can not exchange the crystal).
can anyone suggest a method that i may achieve faster switching PWM ? i am open to suggestions or web links describing off-board analog circuitry that performs high frequency PWM that is , somehow, controlled by the slower movuing 68HC11. schematics here would be a great help.
thx
Mr.Cool
overclock hc11
ok, answering my own question ....
i think this device would work:
h**p://focus.ti.com/docs/prod/productfolder.jhtml?
genericPartNumber=UC3524
this PWM generating IC depends on an analog voltage to control it (up to 300KHz or something rediculous). of course, the 68HC11 does not have Digital -> Analog output pins... BUT, you can create PWM signal on an output pin, low-pass filter the PWM and ::poof:: you have an analog signal (which can be changed by modifying the PWM duty cycle).
Mr.Cool
increase the frequency of a pwm
For 8 bits and 4MHz busclock (crystal is 16MHz):
Max PWM frequency= 4000000/256=15625Hz.
No way to achieve higher frequency without lowering of resolution.
For 60KHz PWM period should be 4E6/60k=66-67 ticks of E-clock or
little more than 6 bits of resolution.
For 8 bits & 60kHz PWM you need 15.36MHz bus clock or
HC11 with 61.44MHz crystal. No PIC16or18 controller exists for such
PWM speed :).
Good luck
hc11 analog output
get it too run on a pic platform
and peek the speed avalible using a senix{ubicom chip}
so you see there is a pic that totaly outperforms all the others
running at a core speed of 75 / 4
if you take 4 /75 youll get the single ins time 54ns for 1 ins process
so this will give you more than enough overhead to get a stable high res routine
{debug the routine internal to the chip then it is easy to adjust loops and times etc to get the pattern correct and linear stepping} first use a routine you made to run slowly on a pic .. its lots easier
i am sure youll get what you need
an sx18 will give enough ... power
so.....
how to increase the frequency of a pwm output
i decided to go with the PIC chip method and drop the 68HC11 all together. the pic chip of choice is the 16F877 with 20MHz crystal. with a prescalor of 1:2 (is this the smallest?) i get an E-clock of 10MHz. this is some 5 times more fast than the 6811 with a 2MHz E-Clock.
therefore, my max PWM speed should be 15KHz * 5 = 75KHz.
goal achieved
my only problem now is that PIC chips are hard to learn!!! BANK1/0 memory, what's that~!? hahaa
Mr.Cool
maxx pwm
i will explain banks to you and registers
TRIS is too set the register by like sloting in a program card
of bits I or O 1 or 0
this value is moved into the tris {basicaly a static variable}
by the movlw B'11100000' binary string
and setting eact port in the order you need changing to the bank you want to tris next
finaly finishing with the one you want too use first {usually the one you started and tris first.....
memory ports are the same for eeprom and also external
the hard part comes from i2c etc
so use some premade routines from the microchip site
w is a temp register for moving data
depending on how you tris'd port's select string depends on the order of int and read write routine execution
so abcde is optimum
but it depends on realy the order your it goes about its routine
and ports in memory are the same as ports in registers
access by priority of needs
so bank 1 can never be bank 0 etc at the same time
to avoid colussions
each port is set lower or higher at a point in the natural hirachy of the registers and ports {given a perfect single cycle operation routines setup}
nice too see you got it hammered out ok...
pulse scaller is the way
well done
frequency of pwm on 20 mhz crystal
goal achieved
Mr.Cool
1. HC11 with 2MHz Eclock can generate in best case 7.8125kHz PWM
output with 8bits of resolution, not 15kHz. + It hasn't hardware PWM
generator -so it's difficult to generate outputs for near to minimum and
maximum output values. 2kHz sounds more real.
2. Max PWM source clock for 16F877 (20MHz crystal) is 5MHz and for
8bit resolution you can get 5e6/2^8=19531.25Hz Max PWM frequency.
For 60kHz PWM you can get 5e6/60k=83.3 max PWM period value
or 6-7bits of resolution. No way to make it better. Can you
overclock PIC16F877 to 61.44Mhz crystal clock(15.36MHz bus clock)?
I don't know if Scenix has hardware PWM. If no for software
PWM 8bits*60kHz it should have 20-30MHz of busclock if you want
full range of output 0..255.
68hc11 schematics
thx for the tips SIMBOX. unfortunately i am not familiar enough with PICs to understand 90% of what you wrote! ha. i will refer to it later after i do more reading.
i am using Pic Basic Pro (V2.42) as the compiler with microcode studio as my editor. i am understanding that the bic basic pro will handle all of the Banking issues (fingers crossed) and so i need not know how they work.
i see now that the PIC can not achieve 60KHz :(
according to : h**p://w*w.3base.net/produkter/komponenter/pic16f877.php
Maximum PWM frequency @ 8-bit resolution = 32 kHz, @ 10-bit resolution = 8 kHz
hmmm.... maybe 32K will be fast enough.. it is after all to control a switching element in a boost converter (DC-DC).
Mr.Cool
