Increase my frequency of Oscillation from 8 to 32 MHZ
Neyolight
Full Member level 5
Full Member level 5
World
Hi
I am currently using 8Mhz ( instruction cycle = 2 Mhz). I know with PLL I can increase this to 32MHZ...but HOW is my question !
Currently I have:
#pragma config OSC = INTIO67
OSCCON = 0b01110010; //select 8 MHz clock
Can someone plzzzzzzzzz tell me how I can increase 8 to 32 MHz!!
Also if and when I do manage to get my Fosc to 32 , would my instruction clock be Fosc/4 = 32/4 = 8Mhz?
Thanks
Typically the PLL is configured by the Configuration Settings.
To which PIC are you referring?
BigDog
Same old PIC of mine PIC18F4620 !
My frequency counter is giving me 0s , so I though of increasing the Fosc to Max possible (32Mhz)
Judging for your other posts, if the PIC in question is the PIC18F4620 the PLL is actually configured via register setting when configured in conjunction with the Internal Oscillator.
Reference: PIC18F2525/2620/4525/4620 Datasheet, Section: 2.6.4 PLL IN INTOSC MODES, Pg. 26
The 4x frequency multiplier can be used with the
internal oscillator block to produce faster device clock
speeds than are normally possible with an internal
oscillator. When enabled, the PLL produces a clock
speed of up to 32 MHz.
Unlike HSPLL mode, the PLL is controlled through
software. The control bit, PLLEN (OSCTUNE<6>), is
used to enable or disable its operation.
The PLL is available when the device is configured to
use the internal oscillator block as its primary clock
source (FOSC3:FOSC0 = 1001 or 1000). Additionally,
the PLL will only function when the selected output frequency
is either 4 MHz or 8 MHz (OSCCON<6:4> = 111
or 110). If both of these conditions are not met, the PLL
is disabled.
The PLLEN control bit is only functional in those internal
oscillator modes where the PLL is available. In all
other modes, it is forced to ‘0’ and is effectively
unavailable.
BigDog
---------- Post added at 22:16 ---------- Previous post was at 22:09 ----------
You'll also need to enable the PLL via the OSCTUNE register, bit PLLEN.
Example:
OSCTUNE = 0b01000000;
You should verify the correct #define for the OSCTUNE register is indeed OSCTUNE.
Yes.
BigDog
Yup from the data sheet ....In order to enable PLL
1) Work with 4Mhz or 8Mhz ( Checked in OSCCON register)
2) Device is configured to use internal oscillator block as its primary clock source ( OSC = INTIO7 , so that I can see the clock on RA6)
The frequency at RA6 is 2.24 Mhz when it should read 8 MHz ( 32/4)
/* Clock Setup*/
OSCTUNE = 0b01001111;
 /* Clock Setup*/
Why are you changing the factory calibrated frequency of the internal oscillator?
Try:
Instead of:
Or better yet, try:
OSCTUNE |= 0b01000000;
Which sets the PLLEN leaving the other bits unchanged.
BigDog
Yup that gives me 2 MHz at RA6 .
I was fiddling around with these bits to get MAX frequency out.
OSCTUNE (BIT 4:BIT0)
bit 4-0 TUN4:TUN0: Frequency Tuning bits
01111 = Maximum frequency
00001
00000 = Center frequency. Oscillator module is running at the calibrated frequency.
11111
10000 = Minimum frequenc
---------- Post added at 10:28 ---------- Previous post was at 10:27 ----------
By the way, whats " |= " this?
00001
11111
10000 = Minimum frequency
The Oscillator Tuning Bits are usually utilized to compensate for frequency drift due to Vdd or temperature changes.
The operator "|" is a Bitwise OR and combining them with an assignment operator "=" simplifies the statement.
For example:
A = A | B;
Is equivalent to:
A |= B;
Either statement assigns the result of "A OR B" to "A."
BigDog
" FOSC3:FOSC0 should be 1001 or 1000 " for PLL to work.....Its only set in the configuration bits I suppose [OSC= INTIO7 or INTIO67]?
Yes and No.
Yes, if the oscillator source is the internal oscillator, INTIO7 or INTIO67 are the only valid Internal Oscillator settings.
However, if an external clock source is utilized there are of course other valid Configuration Register Settings, HSPLL for High-Speed Crystal/Resonator.
I should also mention, when using an External High-Speed Crystal/Resonator, the PLL is properly configured and enabled via other Configuration Register Settings.
BigDog
Yup, one and the same..
TABLE 23-1: CONFIGURATION BITS AND DEVICE IDs
File Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0
Default/
Unprogrammed
Value
300001h CONFIG1H IESO FCMEN — — FOSC3 FOSC2 FOSC1 FOSC0 00-- 0111
300002h CONFIG2L — — — BORV1 BORV0 BOREN1 BOREN0 PWRTEN ---1 1111
I see , then why don't I get 32Mhz with this?
/* Clock Setup*/
/* Clock Setup*/
Hi, yes had the same problem , just make OSCON bit 1 a zero and it works fine
Edit, seems it needs to see the Int Osc as primary not int ??
OMG that worked! It gives me 8MHz at Ra6 (Fosc = 32 Mhz) =D
Thanks wp100 =)
Going by the data sheet, changing OSCON 10 to 00 switch from Internal Oscillator block to Primary Oscillator - not sure how it works but im happy that it does !
Will go test my frequency setup, hope I can capture my frequency now *fingers crossed*
Exactly.
Reference: PIC18F2525/2620/4525/4620 Datasheet, Section: 2.7 Clock Sources and Oscillator Switching, Pg. 28
Like previous PIC18 devices, the PIC18F2525/2620/
4525/4620 family includes a feature that allows the
device clock source to be switched from the main
oscillator to an alternate, low-frequency clock source.
PIC18F2525/2620/4525/4620 devices offer two alternate
clock sources. When an alternate clock source is enabled,
the various power-managed operating modes are
available.
Essentially, there are three clock sources for these
devices:
• Primary oscillators
• Secondary oscillators
• Internal oscillator block
The primary oscillators include the External Crystal
and Resonator modes, the External RC modes, the
External Clock modes and the internal oscillator block.
The particular mode is defined by the FOSC3:FOSC0
Configuration bits. The details of these modes are
covered earlier in this chapter.
BigDog
Got it!
My frequency counter still gives me 0 but at a faster rate =P
So the problem lies somewhere else I suppose!
