jaya krishna
Member level 1
- Joined
- May 10, 2012
- Messages
- 41
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- India,coimbatore
- Activity points
- 1,770
any body help for my problem....eeprom cannot write and read the exact value....
24256.c
it display on lcd is 0 0 0 0 but it should display hello world
hi every one ,now i get string first character, but value cannot be increment, it display h h h ...but i need to display the Hello world....by using eeprom i2c....
#include <16F877a.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use i2c(MASTER, FAST, SCL=PIN_C3, SDA=PIN_C4, FORCE_HW)
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
#include <24256.c>
#define rs PIN_C0
#define rw PIN_C1
#define en PIN_C2
void lcdcmd(unsigned char cmd);
void lcddata(unsigned char volt);
init_ext_eeprom();
char line1[]= {"Hello world"};
void main()
int8 i;
int8 buff=0,buffer[10];
set_tris_b(0x00);
//set_tris_c(0xF8);
lcdcmd(0x38);
lcdcmd(0x0E);
lcdcmd(0x01);
lcdcmd(0x06);
lcdcmd(0x80);
while(1)
// Write "Hello World" to external eeprom chip.
for(i = 0; i <10; i++)
write_ext_eeprom(i,line1);
// Read characters from the external eeprom chip
// and write them into a RAM buffer.
buffer = read_ext_eeprom(i);
buff = buffer;
lcddata(buff+0x30);
output_b(cmd);
output_low(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
output_b(volt);
output_high(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
[/PHP]
any body help me....
PHP:
#include <24256.c>
#define rs PIN_C0
#define rw PIN_C1
#define en PIN_C2
void lcddata1(char *dat);
init_ext_eeprom();
char line1[]= {"Hello World"};
void main()
int8 i;
int8 buff=0,buffer[17];
set_tris_b(0x00);
//set_tris_c(0xF8);
lcdcmd(0x38);
lcdcmd(0x0E);
lcdcmd(0x01);
lcdcmd(0x06);
lcdcmd(0x80);
while(1)
for(i = 0; i <= 10; i++)
write_ext_eeprom(i, line1[i]);
// a= line1[i];
//printf("%c",a);
for(i = 0; i <=10; i++)
buffer[i] = read_ext_eeprom(i);
buff = buffer[i];
lcddata(buff+0x30);
// lcddata(buffer[i]);
// Display the message on the LCD.
//printf(lcd_putc, buffer);
output_b(cmd);
output_low(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
output_b(volt);
output_high(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
output_high(rs);
for(;*dat!='\0';*dat++)
lcddata(*dat);
PHP:
//// Library for a 24LC256 serial EEPROM ////
//// init_ext_eeprom(); Call before the other functions are used ////
//// write_ext_eeprom(a, d); Write the byte d to the address a ////
//// d = read_ext_eeprom(a); Read the byte d from the address a ////
//// The main program may define eeprom_sda ////
//// and eeprom_scl to override the defaults below. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
#ifndef EEPROM_SDA
#endif
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE 32768
void init_ext_eeprom()
output_float(EEPROM_SCL);
output_float(EEPROM_SDA);
void write_ext_eeprom(long int address , BYTE data)
short int status;
i2c_start();
i2c_write(0xa0);
i2c_write(address>>8);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xa0);
while(status==1)
i2c_start();
i2c_stop();
BYTE read_ext_eeprom(long int address) {
BYTE data;
i2c_start();
i2c_write(0xa0);
i2c_write(address);
i2c_start();
i2c_write(0xa1);
data=i2c_read(0);
i2c_stop();
return(data);
PHP:
#include <24256.c>
#define rs PIN_C0
#define rw PIN_C1
#define en PIN_C2
init_ext_eeprom();
void main()
int8 i;
set_tris_b(0x00);
//set_tris_c(0xF8);
lcdcmd(0x38);
lcdcmd(0x0E);
lcdcmd(0x01);
lcdcmd(0x06);
lcdcmd(0x80);
while(1)
write_ext_eeprom(i,line1[i]);
buff = buffer[i];
lcddata(buff+0x30);
output_b(cmd);
output_low(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
output_b(volt);
output_high(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
[PHP]
24256
#include <24256.c>
#define rs PIN_C0
#define rw PIN_C1
#define en PIN_C2
init_ext_eeprom();
void main()
int8 i;
set_tris_b(0x00);
//set_tris_c(0xF8);
lcdcmd(0x38);
lcdcmd(0x0E);
lcdcmd(0x01);
lcdcmd(0x06);
lcdcmd(0x80);
while(1)
buff = buffer;
lcddata(buff+0x30);
output_b(cmd);
output_low(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
output_b(volt);
output_high(rs);
output_low(rw);
output_high(en);
delay_ms(1);
output_low(en);
[/PHP]
