Inconsistent results between Terminal Wave Port and Terminal Lumped Port when simulating a flat FCC cable ... can someone help me ?
rdpdo2002
Junior Member level 2
Hello,
I would like to simulate the system {connector1 + 24 inches cable + connector2}, something like this :
Obviously, I cannot simulate this because of the computing cost....
But under HFSS, I can use deembedinbg using wave ports (but not using lumped ports) so my idea is to simulate :
- the S-parameters of the connector1 inputs / output
- a little length of cable using wave ports
- dembed to get the 24 inches lenght of cable
- the S-parameters of the connector2 inputs / output (which are the same as connector1)
- Add all the circuits in series
I am just wondering if I can add the S-parameters circuits in series and if it is correct to add them to get the total system s-parameters ?
Thanks you for your advice :)
Hello,
It's a shield 100ohms differential cable
I can get the Z by TDR.
Thanks 👍
Hello,
I am trying to simulate a 100 ohm differential impedance FCC flat cable (Molex) but I can't find consistent results when using the Lumped or Wave terminal ports.
My aim is to simulate 24 inches long cable. But as it is very processor demanding, I want to simulate a portion of the cable (here 5 cm) and virtualy increase the lenght of the cable by de-embeding it.
Problem is I cannot use lumped ports because using lumped port do not give the possibility to use de-embeding for extend lenght of cable. So I need to to use wave ports.
The structure of the cable is following and I am trying to simulate common signal to get 50 ohm impedance :
When using terminal Lumped port, I got 50 ohm result for a single signal with two GND around it (GND/ SIG / GND ) which is consistent with the 100 ohm diff cable :
Unfortunatly, when using terminal wave port, I got 38 ohms instead of 50 :
I have tried to modify a little the port geometry so that there is 3 digit scale for the E-field on the wave port, and a better e-filed vector distribution but I still get 38 ohm instead of 50 ohm...
I think the geometry for my port is OK because if I increase it like this, I got oscillation on the TDR response, but still 38 ohms:
Do someone have any idea to get better result using wave port ?
Thanks you very much !
LaTeX Commands Quick-Menu:
