.inc files - Do I only need 7 segment.ASM and mikroe184.inc
Re: .inc files
Assume you are trying to do the seven segment instead of the lcd ?
You will need all those .inc files but the one for the 84 will need to be changed for your 690 chip including the configuration settings.
Those tutorials are really designed to run with mikros hardware etc, perhaps you might find this tutorial a bit more complete and well proven - the guy is also available should you need help.
http://www.winpicprog.co.uk/pic_tutorial.htm
    newbie111
Re: .inc files
Thank you for your reply.
I am planning to work with both.
