grizedale
Advanced Member level 3
Hello,
I am doing a half-bridge smps and the primary current sensing is via a bridge rectified current sense transformer like on figure 8, page 18 of the following…
The problem of this current sensing method is that it is difficult to get good accuracy of the current sense because of the variability of the Vf of the diodes in the current sense rectifier
In my circuit, (I am actually using the MC34025 controller) it is voltage mode and the current sense is just to give a primary current limit.
-but I really do need this current limit to be accurate, because the FET has a distinct current limit…..and the output inductor can saturate.
The diodes that I’m using in the (full-bridge) current sense rectifier are the following:-
http://www.fairchildsemi.com/ds/BA/BAV70.pdf
It is seen how widely the Vf of eg the BAW56 diodes vary with temperature.
Are there any diodes that have a much tighter tolerance on Vf than those above?
-otherwise my current sense is just too inaccurate.
