[SOLVED] in s domain is s a frequency
Hassan Munir
Newbie level 6
how to solve for reactive component knowing a zero occurs at a particular frequency
So i have the following problem
How do i solve for a specific component given that the a zero occurs at a particular frequency
so the numerator of my Transfer function is "R3(sC2L1 +1)" and I am told that a zero occurs at 2.7 MHz
I know the values of R3 and C2, the only component I am missing is the inductance L1
my initial go at this was to set s=jw , w=2*pi*f , and set the above numerator to zero to solve for inductance however I get stuck here
L= -1/(jwC2) which doesn't make sense since inductance is not complex(I know reactance is) and it can't be negative.
So how I get solve for L1 using the information I know.
Please help
Are you sure about the transfer function ? The dimension of sC2L2 is pF; probably the correct expression is s^2C2L2 that is dimensionless (unless the "1" of sC2L2+1 is pF). If it is so:
-w^2*C2*L2+1 = 0 ==> L2=1/(w^2*C2)
Dear Hassan Munir
Hi
Has you problem any circuit ?
And what do you mean by "L= -1/(jwC2)" ??!
If you tell me a bit more explanation , perhaps i can help you .
Best Wishes
Goldsmith
Thank you albbg!
You are correct I actually missed the extra s in my calculation and now i got s^2 in the numerator
cheers,
s is in rad/s (angular frequency). The factors 1/(RC), R/L and 1/sqrt(LC) are also in rad/s. sqrt(L/C) is in ohms.
