nayakajit87
Member level 5
Here is my code written on Arduino.I wanted to load OL_Time value if
R,Y, current range of
if(perc1>RYBcurrent OL_Time=20
else
if(perc5>RYBcurrent OL_Time=15
else
if(perc15>RYBcurrent OL_Time=10
else
if(perc20>RYBcurrent)
OL_Time=5
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 unsigned int OL_Point = 10; unsigned int percentage2C_Limit = 20; unsigned int percentage5C_Limit = 50; unsigned int percentage10C_Limit = 100; unsigned char OL_Curve = 1; unsigned int OverLoad_Flag = 0; unsigned char Pgm_mode = 0; unsigned int OCRT_Dly_Cntr = 0; unsigned int OL_Time = 30; unsigned int OLTR_Time = 0; unsigned char Milli10_Sec_Cntr_X = 0, Milli100_Sec_Cntr_X = 0, Milli1000_Sec_Cntr_X = 0, Power_on_Valid_Cntr = 0; unsigned char Cntrl_flag = 1; unsigned int Rph_Current = 16; unsigned int Yph_Current = 16; unsigned int Bph_Current = 16; unsigned int Percenatge_Calculated = 0; unsigned int Counter_OCRT = 0; unsigned char Rph_OLFlag = 0; unsigned char Bph_OLFlag = 0; unsigned char Yph_OLFlag = 0; float Rph_Current_Float = 0.0; float Yph_Current_Float = 0.0; float Bph_Current_Float = 0.0; float OL_Point_Float = 0.0; float Per1_Cal = 0, Per5_Cal = 0, Per10_Cal = 0, Per15_Cal = 0, Per20_Cal = 0; float Per30_Cal = 0, Per40_Cal = 0, Per50_Cal = 0, Per60_Cal = 0, Per70_Cal = 0, Per80_Cal = 0, Per90_Cal = 0, Per100_Cal = 0; void setup() { // put your setup code here, to run once: Serial.begin(9600); } void loop() { if (((Rph_Current > OL_Point) || (Yph_Current > OL_Point) || (Bph_Current > OL_Point))) { if (OL_Curve == 1) { Percenatge_Calculated = ((int)(OL_Point * percentage2C_Limit) + OL_Point); Rph_Current_Float = Rph_Current * 1.0; Yph_Current_Float = Yph_Current * 1.0; Bph_Current_Float = Bph_Current * 1.0; OL_Point_Float = (double) OL_Point / 1.0; Per1_Cal = (OL_Point_Float + ((OL_Point_Float * 1) / 100)); Per5_Cal = (OL_Point_Float + ((OL_Point_Float * 5) / 100)); Per10_Cal = (OL_Point_Float + ((OL_Point_Float * 10) / 100)); Per15_Cal = (OL_Point_Float + ((OL_Point_Float * 15) / 100)); Per20_Cal = (OL_Point_Float + ((OL_Point_Float * 20) / 100)); // Percenatge_Calculated= OL_Point+((OL_Point*1)/100; Counter_OCRT++; function (); } } else { // Counter_OCRT = 0; OverLoad_Flag = 0; Rph_OLFlag = 0; Bph_OLFlag = 0; Yph_OLFlag = 0; } delay(1000); Serial.print("RPH:"); Serial.print(Rph_Current); Serial.print("\tYPH:"); Serial.print(Yph_Current); Serial.print("\tBPH:"); Serial.print(Bph_Current); Serial.print("\t OL_Point_Float:"); Serial.println(OL_Point_Float); Serial.print("RPH-float:"); Serial.print(Rph_Current_Float); Serial.print("\tYPH-float:"); Serial.print(Yph_Current_Float); Serial.print("\tBPH-float:"); Serial.println(Bph_Current_Float); Serial.print("Per1_Cal:"); Serial.print(Per1_Cal); Serial.print("\tPer5_Cal:"); Serial.print(Per5_Cal); Serial.print("\tPer10_Cal :"); Serial.print(Per10_Cal); Serial.print("\tPer15_Cal:"); Serial.print(Per15_Cal); Serial.print("\tPer20_Cal:"); Serial.println(Per20_Cal); Serial.print("OL_Time:"); Serial.println(OL_Time); Serial.println("..................................................................................."); delay(1000); } void function () { if (Counter_OCRT >= 5) { // OverLoad_Flag = 1; Counter_OCRT = 0; if ((Rph_Current_Float >= Per1_Cal) && (Per5_Cal <= Rph_Current_Float) || (Yph_Current_Float >= Per1_Cal) && (Per5_Cal <= Yph_Current_Float) || (Bph_Current_Float >= Per1_Cal) && (Per5_Cal <= Bph_Current_Float)) { OL_Time = 20; OverLoad_Flag = 1; } else if ((Rph_Current_Float >= Per5_Cal) && (Per10_Cal <= Rph_Current_Float) || (Yph_Current_Float >= Per5_Cal) && (Per10_Cal <= Yph_Current_Float) || (Bph_Current_Float >= Per5_Cal) && (Per10_Cal <= Bph_Current_Float)) { OL_Time = 15; OverLoad_Flag = 1; } else if ((Rph_Current_Float >= Per10_Cal) && (Per15_Cal <= Rph_Current_Float) || (Yph_Current_Float >= Per10_Cal) && (Per15_Cal <= Yph_Current_Float) || (Bph_Current_Float >= Per10_Cal) && (Per15_Cal <= Bph_Current_Float)) { OL_Time = 10; OverLoad_Flag = 1; } else if ((Rph_Current_Float >= Per20_Cal) || (Yph_Current_Float >= Per20_Cal) && (Bph_Current_Float >= Per20_Cal)) { OL_Time = 5; OverLoad_Flag = 1; } } }
