In QuartusII, how to covert a *.tdf file to a *.gdf file?
edaboardman
Junior Member level 3
convert tdf to gdf
Thanks!
convert ahdl tdf to gdf
QuartusII don't have the tool, that convert *.tdf to *.gdf. You can convert *.gdf file to *.vhd, *.v, or *.tdf.
Aldec (simulation tool) have tool, that convert text on the HDL to the graphic, but Aldec don't work with *.tdf file.
If you want to see the structure of you project (without modifying it), use the RTL Viewer
Re: In QuartusII, how to covert a *.tdf file to a *.gdf file
thank you, RTL viewer is work.
but the result isn't suitable for anylies the tdf file.
for example, the ddf[7..0] are showed in seperated mode:8 ddf; and every member of bus is showed seperated. this leads the figure is tedious.
how to simplify the result?
