In PrimeTime, whats are -start_end_pair and -cover_design in report_timing cmd?
majd229
Member level 2
Member level 2
Hello,
Im trying to view setup and hold times, but i cant seem to figure out the difference between the following:
(for either min or max delay type):
report_timing -path_type summary -max_paths 10000
report_timing -start_end_pair -path_type summary
report_timing -cover_design -path_type summary
I read the documentation, but i dont quite understand it. They all return different # of paths in some cases, and same # of paths in others, and i cant see the pattern.
What i want to do is, report ALL paths (in summary mode) so i can read the setup/hold times in the 3rd column easily, whether violating or not.
But i cant figure out which option to use to get FULL coverage and whats the difference between these options (none, -start_end_pair, -cover_design).
Any help is appreciated.
Thanks
