IN Cadence ADE-L/XL , force netlist to run before every re-run ?
Analog.World
Newbie level 6
Newbie level 6
Hi All,
In Cadence ADE-L , typically when one hits "SIMULATION" Button , it checks whether the schematic is updated or not w.r.t the previous run. If modified, it re-creates the netlist and follows with the simulation.
Sometimes , this internal checking mechanism of cadence fails and simulation gets fired on old netlist. This is a major concern.
Is there a way to force ADE-L to run the netlister always ,i.e. irrespective of the schematic modification status.
Regards
You didn't reveal your tool version. AFAIR, at least earlier versions showed a netlist button - meant as a command!
Hi erikl,
It is ADE-L , part of cadence IC6.1.6
