T
treez
Is it the impedance which could critically damp the resonance?.
The expression SQRT(L/C) gives the magnitude of both the inductive and capacitive impedance at w=wo:
I think SQRT(L/C) ohms is that resistance that gives "critical damping" to the LC series circuit......ie it damps the ringing, but not too much.
I wonder if SQRT(L/C) can be termed the "critical damping resistance for a LC series circuit"?
I believe that SQRT(L/C) makes the LC ringing decay with an exponential (1/e) envelope?
"Critical damping" is the minimum amount of damping that gives no overshoot or ringing. To achieve critical damping, we need Q = 0.5I think SQRT(L/C) ohms is that resistance that gives "critical damping" to the LC series circuit.....
If you think about that for a moment, you'll realise it's complete nonsense."critical damping"....just means the envelope of the decay in the ringing has gone down to 1/e times what it started out at after one second
thanks I see what you mean.....maybe the engineer meant that we should put R=SQRT(L/C) ohms in the primary of the gate drive transformer, and another R=SQRT(L/C) in the secondary of the (1:1) gate drive transformer....this gives 2*SQRT(L/C) total, and gives "critical damping"Thus if you set R = sqrt(L/C) then Q=1 and the circuit is underdamped. For critical damping you need R = 2 * sqrt(L/C)
I thought LC circuits *always* ring?...even if they have series resistance....the resistance just makes the ring die off exponentially...it still rings though?"Critical damping" is the minimum amount of damping that gives no overshoot or ringing
Or maybe he simply meant what he said. Maybe he considers Q=1 to be ideal in that application, or maybe the exact amount of damping isn't important and Q = 1 is "good enough".thanks I see what you mean.....maybe the engineer meant that we should put R=SQRT(L/C) ohms in the primary of the gate drive transformer, and another R=SQRT(L/C) in the secondary of the (1:1) gate drive transformer....this gives 2*SQRT(L/C) total, and gives "critical damping"
I don't know if there's a name for it.SQRT(L/C) is called "characteristic impedance" with microwave transmission lines....do you know what its called for low frequency analog?....is it simply the "critical damping resistance/2"?..is that what its called?
No. It depends on the amout of damping.I thought LC circuits *always* ring?
1) I assume you mean "sqrt(L/C) = 0.5Ω". That would make sense.I am sure that if sqrt(L/C) = 0.5, then if a 2A current source suddenly runs into a series LC circuit, then the peak ringing voltage on the capacitor is 2*0.5 = 1V?
