improving accuracy of a divider circuit
gary36
Full Member level 4
Full Member level 4
I have to implement a function which outputs the relation y=1-(a/b), where b>a and a/b ratio varies from 0.96 to 0.999, with minimum step size of 2mV.
I have looked at analog options such ad633 and ad734. But there accuracy is poor with respect to the requirement. Is there a way to improve the divider accuracy using just analog compoenents?
where and how?
It coulbe be litterally anything: PC, cell phone, C code, excel, breadboard, FPGA ...
What are the input values? analog, digital, what range, what resolution?
How fast / how often do you need it to be calculated? Or what settling time do you expect?
What is the signal´s frequency range?
"A relation" is unitless ... it can´t be "mV".
What are you talking about?
If you want to discuss in mV then you need to give the "ratio to voltage" factor.
From the information you give: the output range will be: 0.001 ... 0.04. Is this correct?
What is your accuracy requirement?
And: an accuracy error can be calibrated out. (While a precision erro can not be calibrated out .. since it varies)
Klaus
Regards, Dana.
LaTeX Commands Quick-Menu:
