Nathan1
Junior Member level 3
The matching network is well matched at 2.45 GHz and improves the rectifier efficiency but S21 values are still around -80 dB (which should be around 0 to -3dB). The S21 values improve a little bit when I reduce load, but efficiency degrades too much. What can be done to improve the S21? The rectifier circuit and simulation results are attached. Thanks in advance.
