Importing netlist to Allegro PCB Designer warnings
teddybear211
Newbie level 5
Newbie level 5
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol 'B3F-1000_35D' for device 'SW PUSHBUTTON_B3F-1000_35D_SW PUSHBUTTON' not found in PSMPATH or must be "dbdoctor"ed.
#2 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-337): Unable to load symbol 'SPDT_EG1206' for device 'SW_SL_SPDT_SPDT_EG1206_SW_SL_SPDT': WARNING(SPMHUT-127): Could not find padstack 109R86_1. [help]
I had a lot of warnings before and managed to fix them by fixing the paths for my PADPATH and PSMPATH. However even after fixing those I have 2 errors still show up.
I had managed to fix my first warning, now I only have this
However in my symbol library 'SPDT_EG1206 is correct for the part in my netlist. I believe the warning has to do with padstack 109R86_1, but I'm not sure what to do from here.
open the symbol B3F-1000_35D and then select the pad and save it your footprint location.(you are not assign the psmpath correctly in library location)
setup--->user preference-->select path in left side of pop-up menu (double click it)-->library and then select the psm path and pad path location.(your pad and symbol file location)
yes, that's right.
