IMPORTANT VERILOG CODING PROBLEM
choonlle
Full Member level 2
Full Member level 2
AFRICA
Case A:
always @(ctrl or dataIn0 or dataIn1)
dataOut <= (ctrl) ? dataIn1 : dataIn0;
Case B:
dataOut = (ctrl) ? dataIn1 : dataIn0;
Which case is correct? WHY?
Case A: is correct!
    choonlle
No Case B is correct. Because combinational logic.
case B is correct as it is combinational assignment. bcoz for combinational circuit use blocking assignments. h/w in both the cases will be the same.. it only affects simulation
Sachin
I make final conclusion :
A is correct !
Finally, i get this answer from Verilog Coding & Synthesis Book.
Can you please upload that book
