your logo and images must be in .DXF (drawing interchangeable format) if have it means
file----> import---> dxf and then DXF IN window open and then----> location file , and fill logo class
and then select increment selection,default text table
NOTE : DXF file and board file dimension must be in same (like mm or mils )
View attachment error.txt
hello kapil,
I also did like this so many times but i'm getting the error here i attached an error file please find that and please kindly send me the solution i'm waiting for your replay,I'm trying its from past 3 weeks plz replay me
isuue is with your DXF. Splines are not supported by Allegro. Issue is raising because you created the DXF directly from your 3D software ( solid works, proE etc).
Try the following
1. Open the DXF in Visual cad ( inastallation folder/cadence/spb xx.x/tools/layout_plus/vcad)
2.edit --> select all
3.symbol --> explode symbol
4.modify --> explode
5.then save as DXF in some other names.
6. import the new DXF to allegro.
cheers,
Nikhil
Hello nikhil
Thanks for response,here i'm sending my dxf file and image i required on pcb the original image is converted to dxf using img2cad software
I think your DXF donot contain any valid data ( file size is only 9 kb). here I attached screen shot when I opened DXF given by you in a DXF viewer .How ever I followed the steps I mentioned earlier and successfully imported it to allegro. Herer I am attaching the new DXF. You can import to your allegro using the normal procedure ( file--> import--> DXF)
hello nikhil,
Thanks for responding, I am also succesfully imported the dxf into allegro can u plz tell me frist how to convert images or logos into dxf.
