import EDIF file into Cadence
rauljin
Junior Member level 2
China
cadence edif
Since I used Cohesion for schematic editor,it can export EDIF files.
now who can tell me how to import them into Cadence?
Thanks in advance!!!
what is edif file
can someone help me to solve it?thanks!
cadence edif import
Have you tried "File/Import/EDIF200..." and "File/Import/EDIF300..." from CIW menu?
import edif into cadence
edif netlist or edif schematic?
just check pulldown menu of ciw, it's there i'm sure.
cadence import edif
Noramlly there are two different vision EDIF:EDIF200 and EDIF 300. And Cadence support both.
importing and exporting a design cadence
Do you make sure the Cohesion can export the design by EDIF? It seems it only can export the symbol by EDIF format.
edif cadence
yes,cohesion can export symbol,I have tried to export EDF file from Cadence,then importting it into Cadence,it's ok,but I used the EDF files from Cohesion into Cadence,it's failure.
now I researched the difference of the two files.
cadence® edif 300
using "dos2unix" command to convert formart,then can import EDIF from cohesion into cadence,
but now I have encounted new question,the cell view was "V1",opened it and its window has nothing.
why and how to solve it?thanks!
export file in cadence
Now I get the same the question
it says "Failed to create schematic sheet. Unable to open cell, msheet, of library,"
crazy...
edif file
who can tell me how to export edif netlist from cadence.thanks
