implementing LOG10 in verilog, please help
ramlogo
Newbie level 3
Newbie level 3
I am trying to work out a LOG10 module in verilog by the tutorial
https://www.mikrocontroller.net/attachment/31117/cordic1.pdf
so far so good, i got this module working and pipelined, and the error is <0.002.
BUT, there is a restriction by this algorithm, that is:
according to the algorithm, the range of input(mW) is restricted to
1/prod(1+2.^(-x)) to 1/prod(1-2.^(-x)), where
0.41942884 < input(mW) < 3.46269378
Now I want to extend the range of input, ideally from 0.0001 to 10000. I tried to pre-scale the the input by the identity: log(a*b)=log(a)+log(b), it works, but at the same time, the error is rising to 0.1(or worse), which is not acceptable.
anyway, here can anyone give me some idea on extending the input range but without any accuency decrease
any advice will be appreciate.
Thank in advance
Regards,
Jerome G. J.
I would prescale with log(x) = log(x' * 2^n)
with n selected in a way that x' is always in the range of 1..2
(in hardware finding n means finding the position of the msb)
this results in log(x) = log(x') + n*log(2)
log(2) can come from a table and you can hold it as percise as you want.
So the final result should always have the similar accuracy
I tried to implement this, but at the moment I have problems with the base algorithm from your paper.
I implemented it, but for numbers around 1.1 I already have a huge error
(similar for numbers around 2.02)
regards
