Implementing an Embedded Multiplier Using VHDL
masai_mara
Full Member level 1
Xilinx multipliers
Can block multipliers be inferred in xilinx from a vhdl function code in a package or module??
Xilinx multipliers
I don't understant the question, do you mean that you want to refer to a multiplier inside your module or package?
In that case, the answer is yes. Based on the help file of the ISE 6.3 you can use the Multi18x18 in your code as it is described here for VHDL:
The following VHDL code demonstrates how to instantiate a Virtex-II Pro™ 18-bit X 18-bit embedded asynchronous signed multiplier.
Insert the following between the "architecture" and "begin" keywords.
component MULT18X18
port(
               A : in std_logic_vector (17 downto 0);
               B : in std_logic_vector (17 downto 0);
               P : out std_logic_vector (35 downto 0)
end component;
Insert the following after the 'begin' keyword
U_MULT18X18 : MULT18X18
port map (
               A => , -- insert input signal #1
               B => , -- insert input signal #2
               P => -- insert output signal
I don't know if this answers to your question, but if you are more specific, I maybe able to help (I have just tarted playing with my Spartan 3 board).
BR,
/Farhad
Re: Xilinx multipliers
I wanted to know whether I can use func mult18x18 instead of using it as a component. And similarly can I use the core gen wizard generated multiplier(chosen with zero pipelining) as a function instead of as a component. I think it should be possible as a multiplier can be pure comb logic.
thanks
Xilinx multipliers
HI,
You can actually make your own function and wrap it arround the component. It makes it much easier to program and read.
BR,
/Farhad
Yes, you can use * to infer multiplier. If one multiplicant is a constant, some tools infer combinatorial logic.
Xilinx multipliers
"Infer" means to use the * operator in your HDL. It is very convenient and fast, if you pipeline carefully.
If you explicitly place a "MULT18X18", then you are instantiating, not inferring.
The HDL compiler does the inferring. If you use XST then read the XST User Guide -> HDL Coding Techniques -> Arithmetic Operations -> Multipliers.
Also read about MULT_STYLE in the Constraints Guide.
farhada said:
HI,
BR,
/Farhad
You mean I can instantiate a component inside a function.
