Implementing a switch in HSPICE
sharas
Member level 4
Member level 4
Does anybody know how to implement a switch that switches as a function of time in HSPICE?
I would be gratefull,
Thanks,
Sharas
You can used a voltage controlled resistor.
in the syntax below, phi1 is the control signal
and the switch connects 2 nodes, vin and vout.
the resistance between the 2 nodes is 100G ohms when phi1 is 0 volts.
When phi1 reaches 5 volts, the resistance is 1 mOhm = 0.001 ohm.
G1 vin vout VCR PWL(1) phi1 0 0,100G 5,1m
you can also refer here:
https://www.seas.upenn.edu/~jan/spice/spice.overview.html#Switches
Good luck.
Reactions: elec_hi
    sharas
    elec_hi
eecs4ever is correct E element is different as i suggested previously. its G element.
    sharas
h**p://www.seas.upenn.edu/~jan/spice/spice.overview.html#Switches
Good luck.
Thanks,
but Isn't there a way to do a time controlled resistor?
You can make a voltage waveform that depends on time. Call this signal phi1, and use this voltage to control the value of the resistor.
now you have a time dependent resistance.
To make a voltage waveform that depends on time,
you have multiple options.
1. the PWL function :
https://www.seas.upenn.edu/~jan/spice/spice.overview.html#Piecewise
2. the Pulse Function:
https://www.seas.upenn.edu/~jan/spice/spice.overview.html#Pulse
If the behavior is periodic, then its probably easier to use the Pulse function.
good luck!
    sharas
In Hspice there is a element called voltage controled resistance. This could be modeling a switch
