Maitha
Newbie
Hi everyone,
I have a hard time to implement the circuit of LV 25-P voltage transducer, as seen in the figure it is from the datasheet (attached file), I need to simulate it using multisim software with these required values:
Voltage input is 500V where R1=50 kΩ, and Rm=200Ω where the output voltage will be 5V. The supply voltage will be 15 V. I tried my best to do it and the other figure shows my work but I’m also not sure about it, and I don’t know what should I do with 2 & 3 pins from the amplifier where it is not clear what that symbol from the datasheet refers to.
I appreciate all your efforts to help me and hope you all have a nice day.
This is the circuit from the datasheet:
this is the circuit I have done in multisim.
