wls
Member level 4
Hello . I need some example to implement fsm and verilog of Successive Approximate Register ( SAR ) , example 74C905 . Anyone did it before ?
Regards.
Regards.
module sar(
// Outputs
data, eoc,
// Inputs
clk, start, gt
input clk;
input start;
output [7:0] data;
output eoc;
input gt;
reg eoc;
reg [7:0] data, data_nx;
reg [7:0] shift;
always @(posedge clk or negedge start) begin
if (!start) begin
shift <= 8'b10000000;
eoc <= 1'b1;
end else begin
shift <= {1'b0,shift[7:1]};
eoc <= !(shift == 1);
end
end
always @(negedge clk or negedge start) begin
if (!start) begin
data <= 8'b10000000;
end else begin
data <= data_nx;
end
end
always @(data or gt or shift) begin
data_nx = data;
if (shift[7] & gt)
data_nx[7] = 1'b0;
if (shift[6] & gt)
data_nx[6] = 1'b0;
else if (shift[7])
data_nx[6] = 1'b1;
if (shift[5] & gt)
data_nx[5] = 1'b0;
else if (shift[6])
data_nx[5] = 1'b1;
if (shift[4] & gt)
data_nx[4] = 1'b0;
else if (shift[5])
data_nx[4] = 1'b1;
if (shift[3] & gt)
data_nx[3] = 1'b0;
else if (shift[4])
data_nx[3] = 1'b1;
if (shift[2] & gt)
data_nx[2] = 1'b0;
else if (shift[3])
data_nx[2] = 1'b1;
if (shift[1] & gt)
data_nx[1] = 1'b0;
else if (shift[2])
data_nx[1] = 1'b1;
if (shift[0] & gt)
data_nx[0] = 1'b0;
else if (shift[1])
data_nx[0] = 1'b1;
end
endmodule // sar
module test();
reg clk;
wire gt;
reg start;
reg [7:0] din;
wire [7:0] data;
wire eoc;
assign gt = data > din; // Analog comparator
sar sar(
// Outputs
.data (data[7:0]),
.eoc (eoc),
// Inputs
.clk (clk),
.start (start),
.gt (gt));
initial begin
$shm_open("WAVEFORM");
$shm_probe(test,"AS");
clk = 0;
start = 1;
din = 0;
#44;
repeat(255) begin
@(negedge clk);
start = 0;
@(negedge clk);
start = 1;
repeat(10) @(negedge clk);
din = din + 1;
end
#2000 $finish;
end
always #5 clk = ~clk;
endmodule // tests
